- May 10, 2012
- 997
I have been considering converting a lathe of mine to CNC. I had originaly intended to convert it to ballscrews, but leaving the original Acme leadscrews would greatly simplify the installation. This will leave some backlash on both the x and z axes. I know this is very undesirable on a milling machine, but I can see much less reason for not using them on a lathe. Lathes do not climb cut, and there are few instances where the z backlash can cause a problem, and even less with the x axes. I expect there are some members here who have tried this, and I would like to get your take on what was problematic, if you found a solution and what it was and what was just plain anoying about using the Acme screws and dealing with the backlash. This machine will not be used for production, so within reasonable limits, speed is not a major concern, so the additional speed that a ballscrew would provide is not an issue for this machine.
