Following a question raised in a recent thread .......... Am curious, Does anything like this exist as an accessory for the fancy tool and cutter grinders ?
Although I grind tools by hand I have often wondered if its possible to make a jig that would allow me to grind an absolutely perfect semicircle on the end of a piece of tool steel without engaging my brain or eye hand co-ordination.
Would maybe be something like a tiny version of the steve bedair ball turning jig but instead of the tool cutting the workpiece it works the other way around with the tip of the tool rotating against the wheel and being ground into a semi circle.
Or even simpler, a pin on a table that engages into a hole in a toolholder and the pivot point is advanced into the wheel until the desired radius is achieved.
