- Apr 8, 2021
- 155
Helo. I have this steady rest
The ring is 60mm but whith the brass parts I can only fit 52mm. I need to turn a pipe of 55mm OD. So my question is, Can I grind a bit the brass parts to allow the pipe? If the answer is yes, Do I need to apply a special finish to those brass parts? The actual finish is not very good by the way.
Thank you
best regards
Thank you
best regards
