- May 7, 2023
- 2,396
This turned up on FBMP and it was so cute I had to buy it. Its supposedly a Taiwanese copy of a Unimat 4, but I really couldn't find much information on either other than they were both made in Taiwan.
Cute lil thing only about 18" or .5M long, and I was surprised to see the gearcase cover and many other parts are steel rather than plastic. It has a nice, but unmarked Enco style chuck made from steel rather than the zamak ones you see now. Tailstock chuck is nice enough, nothing to write home about but it will do.
Put my hand on it for scale as I didnt have a banana.
This is the handwheel of my Prazi SD400 I just replaced on the tailstock. The hand wheel is only 2.5" or so.
Im not sure if the Unimat 4 had change gear threading or power feed, but this little guy does and it works great. Im missing the threading change gears and only have the feed gears. I believe it has 12 speeds, 6 from belts/sheeves and 6 more via a 2 speed motor. It has a powered lead screw that is turned on/off by a kinda wonky gear engagement method. The gear in front at bottom slides in and out to engage/disengage the drive, but its wobbly and a little difficult to disengage. Ill have to work on that.
Took a .5mm/.020 cut in 6061 without breaking a sweat. I will try some tool steel tomorrow but I need to cut it short enough to fit and didnt have tine tonight.
I'm thinking of making a replica hardinge style tool post for this as the factory one is kind of odd and looks to be made for 10mm tooling, which would be kinda comical on this little thing.
Anyone know anything about these or the Unimat 4?
