- Feb 7, 2013
- 2,534
These Eron PV-1 clamps were well worn when I got them as they were galling badly and ceased to function well. Here is a photo
of the original clamp:
They are a nice looking clamp with a gripping hardened clamping surface that advances to the work at 20 degrees from vertical. They are tightened down
with an Allen key using a huge acme thread. There must be something wrong with the geometry because the acme threads were severely digging into
the cast iron moving part of the clamp as well as chewing up the top stationary part of the acme thread nut.
My choice was to scrap them or try to modify them somehow. The acme threads on the stationary part were severely damaged so I machined them
to a flat surface and fitted in a piece of steel and bolted it to the bottom of the channel using a 5/16 Allen bolt. Also, I machined a lip on the cast
part so that the bolt didn't have to take all the forces.
Here you can see the damaged threads threads on the top of the left part and the area on the bottom of the right hand part
that is showing a lot of wear. The dovetails themselves are still in great condition.
Here you can see the modifications made to the clamp. Also, I machined a square on the top of the nut. The mechanical advantage is a lot
better now as the Acme thread was about 8TPI and my threading modification has 24TPI. The work was somewhat difficult and I have three
more clamps to work on. Most of the machining involved working with the 20 degree angle so somewhat of a challenge.
All in all it was a worthwhile morning project. Hopefully I will be able to get the others done and be able to use them in some future project.
Thanks for reading along.
