- Aug 14, 2016
- 20
I'm (attempting) to make a collet block as practice for making a collet chuck for my Craftsman lathe. My Taig mill used ER16 collets so that is the size collet I'm trying to fit. The collet spec calls for an 8° angle. I set the compound for 8° and then put dial indicators on the Z (carriage movement) and X (the side of the compound as in moves in/out with the carriage) and looked for 0.1406" movement on X for 1" movement on Z since tan(8°) is 0.1406... It didn't take too long to get the angle dialed in.
I thought I'd double check the angle by putting a collet on a mandrel and an indicator between the compound slide and the collet. I checked for a constant indicator reading as I dialed the compound slide in and out. That did not give me warm and fuzzy feelings. An uncompressed collet measures about 8.3° (calculated). I checked a different ER16 collet from a different manufacturer. It, too, was greater than 8°.
So finally to my question. Do I cut the taper to the 8° spec or do I match the collets? Yeah, it's a test piece and I can always do it again, but I'd like to know why the collets don't match the spec.
