- May 7, 2014
- 776
Uggg.... About my 30th Question this month! So much to learn! Thanks for the review if you are reading this. You're all wonderful here.
Engraving (pic below) was done w .125 on a DXF i did today in Draftshight to DolphinCAM V12. about 3500 RPM at 5ipm. I do not have the time to go build and attach a HS router adapter to mount on the quill... But that will come in time. So for now, Which bits have you used in your Mill.
The process I have needs a little clean up and I need to get some better engraving tips for brass and steel work I think. That said, Do I just look and buy the usual HSS / Carbide 1/8 shank stuff that Dremel and off-brand's sell? (link below).
There are: Ball End Mills, V-cutter engravers, Ball head engravers, and the diamond tipped , and finally the stone type tops. Hmmmm I have good results w/ the 1/8" so I am thinking get those again in 1/16 ball nose Mill" and try the V-cutter in HSS? you favorites and/or Suggestions welcome.
My first attempt but is similar to my 2D plasma work, so no big deal really. 3.5" across.
. Need to play and experiment a bit. Looking for your ideas and input.
Note- I have searched and read via the "Similar threads" and did searches on this. Still reviewing. I do search often as well in the archives. Great stuff in there if you take the time to search it. ;-) Not just asking w/o looking ;-)
CG.
http://www.amazon.com/Engraving-Cut...1405895093&sr=8-1&keywords=1/16+engraving+tip
- - - Updated - - -
Here is a seemingly OK priced starter kit in what I was thinking I need?
http://www.2linc.com/engraving_tools_starter_kits.htm
Hey.... this is a cool site. Even have Feeds and Speeds. Now if someone sells a quick spindle/quill to router adapter , I think this may be easy after all. Passing along what I find cool!
CG
CG.
- - - Updated - - -
CG
