I have an engine hoist - a rather expensive one, not the red Horror Freight model - that has an invisible leak or something. I used it early in the year to move a 1-ton lathe, no problems at all. Last week I was moving a 200 pound grinder and I noticed that it was very slowly lowering itself as if I had let off the pressure. Problem is, I hadn't let off the pressure. I checked and it was still shut. So with no load I jacked it up so the arm was parallel to the ground and left it overnight (which turned into three days) and when I went back the arm was all the way down on the ground.
There is no hydraulic fluid leaking anywhere. Not a single drop.
BEFORE I moved the lathe I actually dropped it in such a way that the small inner rod came out of the cannister on the shock-absorber looking piece. Some hydraulic fluid leaked out then but I put it back together and it moved the lathe without a problem. Could it be low on fluid or is there maybe something else going on that's causing it to slowly leak inside but not outside? Maybe a problem with the on/off valve (that little knob with the piece of metal you turn with the pipe-shaped "wrench" to let the pressure off)?
thanks
Joe
thanks
Joe
