- Jan 10, 2014
- 200
I made an attempt at single point threading this weekend, and the results were not great, but better than previous attempts. I am using a PM1236 with a thread dial.
My question is this:
When my number is coming around, in order to make sure the engages on the number, I put a little pressure on the lever just before the number is up (kinda like you would do a stick shift if you were shifting with no clutch), not enough to grind, just enough so that when the threads on the lead screw align with the threads on the half nut it engages. Is this the right or wrong way to do it? I have not done it but a couple of times, and just want to make sure I am not going to tear something up.
Any advice would be appreciated (especially the right way if this is not it).
Thanks yall!
Morgan
Thanks yall!
Morgan
