Hi All
So I purchased a 3/4” cutting width EM for my micro mill to “route” out a 1/8” deep by 2” long cavity in some 3/16” steel. Basically I am creating a 3/4” wide by 2” long by 1/8” deep rectangle with rounded ends. Not the point really.
My question is, any time I have used an end mill for its main purpose, (which I believe to be the use of its end cutting edges), the bit screems and fights as it plunge cuts into the metal. I am running around 3000 RPM and I go very slowly into the steel. (Standard Lowes steel.)
Why does it seems to have such difficulty plunge cutting from the end as opposed to the ease in which my end mills cut from the side?
Is it because using the whole bit plunge cutting a circle has the regular cut and climb cut sides fighting each other?
Any suggestions on how I can start cutting the ends of my 2” long cavity without the bit acting so angry?
And again, the ends are plunge cuts. I cannot come in from the side of the stock because I am creating a cavity with 1/8” side walls.
Without all the description above, I probably could have just asked, is plunge cutting with an end mill always so much more difficult than when feeding the stock into the side of an end mill?
