- Oct 21, 2014
- 2,162
Ok, Just got a RF30 and was trying to work on a piece of Steel. Using an 1/2 inch End Mill, in a 1/2 inch r8 collet. but in going across the piece I noticed that by the end of it, the end mill was not cutting really. Brought it back down to where I started and noted it was not touching. As it moved down the material it was sliding up into the collet. Ok, second try, I cranked down on the draw bar then tried again. Ensured it was a slower speed and feed, Same results It is like it does not work. On all the ones I have used prior I had collet holders on them. Is it normal for them to not hold in collets, I'm normally using much smaller things, (Sherline 5400 mill)
Any help/advice would be greatly appreciated.
