- Feb 5, 2017
- 30
Ok I have a newbie question.
I was playing around making some chips fly last weekend. I was playing with end milling and side milling with a 3/8" and 1/2" HSS end mill on a piece of 2" thick mild steel. I was side milling and getting a fair amount of chatter (enough to shake things and feeling it in the table). So much I was afraid I was going to break damage something. Just a .010 cut would be make things pretty rough. Additionally as proceeding with the cut the end mill would start slipping out of the collet.
I tried varying the RPM between 700 and 1200 RPM but I never felt good about the way it was cutting.
I will note that the surface was rough and uneven (I was trying to square things up).
I pretty much destroyed one end mill. My fault probably going to fast.
Things I have tried so far:
I bought a spindle wrench to help facilitate getting a good hold on the end mill. I cleaned up the collet to ensure it was free of oil, using a couple blasts of CRC. I using collets that bought with the mill from QMT. I gave it another try last night and I think it is better (using the spindle wrench to get a bit more torque) but I still seem to be getting some slipping of the end mill in the collet. I'll try a new end mill today when it arrives but was hoping for some feedback if anyone has any.
My question is should I get an end mill holder rather than using collets?
Should I use roughing end mills for uneven surfaces?
What is a good reference for how deep a cut I can take when end milling & side milling.
I'm good with trial and error but hate to spend more than I need too.
