End Mill For Stainless Steel ?
Plas62
Sep 3, 2013
89
I am going to be manually milling some 1/16" wide, rounded bottom slots .020 to .040 deep in CPM154 stainless. I know I need a ball end end mill and I believe it should be center cutting. Should I be looking at HSS, Cobalt or Carbide? Should the end mill be 2,3 or 4 flute?
Depends on a few things, but overall I prefer Cobalt with a TiAlN coating. 4 flutes are nice for steel usually. Although sometimes 2 flutes are better especially when slotting because the end mill will not climb cut nearly as bad as a 4 flute. Check Zoro tools, sometimes you get some nice deals especially on other shapes like ball nose end mills.
