Enco / RF-128 4x6 Bandsaw Mods
darkzero
Global Moderator
Staff member
H-M Lifetime Diamond Member
Nov 27, 2012
7,912
When I got my first mini lathe I quickly learned that cutting bar stock with the strong arm method was not going to last long. I was going to pick a HF bandsaw until my buddy found me a used bandsaw locally an Enco 4x6 which is a RF-128, made in Tawain. It was practically never used, just sat in the back of some guys garage, still had the stock blade & was never adjusted.
Here it is when I picked it up 2 years ago. Was missing the saw table to be used vertically & the depth stop attachment.
Blade cover was damaged but a replacement from Enco was only $15.
Only thing I've done to it in the past couple of years was adjust blade alignment, change the oil, ditched the stock blade, installed a Fenner Power Twist belt on it, & just use the hell out of it.
For reference, my favorite blades to use are (they last a long time if used properly):
Titanium 6Al4V (which I cut the most): Lennox p/n 12897D2B51638, 6-10 variable tooth bi-metal, 0.025"
MSC p/n 82909524. Also available at Amazon. $25-$35.
General purpose: Irwin p/n 88508, 10-14 variable tooth bi-metal, 0.025" thickness.
Always on sale at Enco for $14.99, p/n 240-4930.
Here's what I use on the blade & in the gearbox.
Although I've been wanting a RF-712N or RF-712G clone from MSC for quite some time now, this little guy has been serving me well & has never let me down yet so I'll continue to use it for now until I really need the larger capacity.
Please feel free to share your 4x6 mods & ideas here if you'd like. Been thinking about a hydraulic downfeed mod too but I haven't looked into it much.
I've just been throwing a carboard box under it to catch chips. I've been meaning to finish my pull out tray project for it & now that I have a mill I decided to make better brackets for it than my original idea.
I started out with a couple pieces of alum bar stock & an alum baking pan from Walmart.
Milled a slot on each bar to serve as the tray slide.
Tapped some holes for the mounting brackets.
Tapped some holes on the body & mounted them in place.
Tray simply slides into place & easily removed for clean up.
I'm pretty happy with it & it works pretty well for being so simple. I'll probably mill the ends of the slides at angle later. Thanks for looking.
Great job on the chip tray. My next purchase is a 4x6 saw.
Thanks Gary! You would definitely put it to good use. It's one of those tools that I can't live without. :)
heh, I did almost the exact same thing with a baking sheet although I was lazy and just put the sheet on the shelf. I like the idea of the mount for it as it frees up the shelf for better uses. that's a nice saw, and I wish I hadn't waited so long before getting it (I have the HF version which looks identical to yours by the way in every way - mobile base, guide knobs and all).
I have the HF version which looks identical to yours by the way in every way - mobile base, guide knobs and all.
I have heard the older green version of the HF were built much better than the red ones. I do remember seeing one on CL & it does look identical to mine.
I guess I will definitely be keeping mine for a while.....
I added a knob to the tray to make it easier to pull out.
I've seen many others add extensions or make new jaws for theirs. I thought about that too but figured adding extensions to the existing jaws would reduce capacity a bit. There were a few times where I actually needed more capacity & had to remove the jaws to get the job done.
So I just relocated the "fixed" jaw. Drilled & tapped new holes which gave me about 1/2" more capacity & brought the jaws closer to the blade. No mod needed to the dynamic jaw, just slide it over.
Before:
After:
Only downside is that I would have to move the fixed back to the original location if I need to cut an angle which I never had to do yet but that's no big deal. So now I can fit 4.5" between the jaws before the dynamic jaw hits the roller guide & if I adjust the dynamic jaw to clear the guide I can now fit 6.5" between the jaws. I could have squeezed a tad bit more out if it but I'm ok with it now. If I make new jaws I could get 8" between the jaws but I don't need to push it, 6" is the widest I've had to cut so far, plus some other things will have to be modded to get 8" between the jaws.
Finally decided to do something about the "knuckle buster". I quickly learned not to use the handle intended for moving the bandsaw around. Holes in the sheetmetal were so bent out of shape that the handle would always slip & I'd get cut or bruised on the frame.
I hammered the holes flat again but I was still scared to use it. It's just held in with cotter pins.
Very simple to fix this. Got some shaft collars from Mcmaster.
Now the handle is nice & solid, can't believe I waited so long to do something about it.
I found that replacing the sheetmetal stand with a welded one that is much stiffer has improved the cut quality.
Nice mods, keep em coming! I really need to learn how to properly weld & get a welder!
Any hydraulic down feed mods here?
