G'day all!
Trawled the forums and google looking for this answer to no avail.
I need to replace the spring in the dial of my cross slide.. I just found it is missing (yes, still rebuilding it).
Anyway, the emco partslist puts it as
"B2A 000 080". "Spring"
I suspect it is simply a bent piece of clock spring that puts tension on the dial to allow it to spin with the handle, yet still a low some movement to zero the dial.
I have no original so no dimensions except the terrible picture in the parts manual. I see I can order one from the UK... but the shippings a little (ahem) pricey for it.
Anyone have the dimensions or a way I can retrofit something to do the job?
Thanks in advance.
Mike
Melbourne, Australia
Thanks in advance.
Mike
