- Jan 21, 2016
- 26
G'day mates,
No, I'm not an Aussie but that greeting has always sounded friendly so....
My question today has to do with emery cloth.
Background:
while attempting to repair a frostproof hydrant out in the barn yard, the plumber I hired used his "vice grip" on the body of the extension rod that connects to the 7 foot rod with the plunger at the bottom of it. The extension rod is connected to a threaded brass connector on the bottom of it and penetrates what is called the"packing nut" which is a threaded brass bushing on top of the handle of the hydrant. (He also grabbed the threads with the same vice grip but I was able to spin a die on that and clean them up.
He scarred the extension rod and it would NOT pass through the packing nut so I put it on my lathe and took a small piece of coarse emery cloth to polish down that scar. After about a minute at a pretty moderate speed, I was able to pass the "packing nut" over the rod. The rod passes through two "O"rings between the packing nut and the brass connecter.
My question is: Did I polish off TOO MUCH with that emery cloth and should I have used a fine grade rather than coarse grade?
The amount of scarring on the rod wasn't all that much but it did prevent passage through the packing nut until I polished it.(It was out of round by a bit in "machinist standards" but not THAT noticeable when assembled in the hydrant.
I am still not good with the tool on the lathe. I was afraid with the rod out of round like that, the tool would cut deeply on one area and not at all on the other side of the rod. AND my lathe still has a good bit of backlash that I am not all that skilled in getting out so that I can believe a .002 change in depth of the tool.
Any suggestions/comments will be much appreciated.
Cheers,
Trim sends
Background:
Cheers,
Trim sends
