- Oct 25, 2023
- 2
I obtained a second hand emco maximat v10p lathe with milling attachment.
Everything works now after many hours of restoration, except:
forward low speed. With low speed switch selected the motor just humms. If I give it slight turn by hand on the chuck, it starts up fine and also goes into full speed.
reverse low and high speed works fine as well as the milling head.
Therefor the capacitor start is not connected correctly.
I shall be very appreciative for someone to send me a pic such as the one attached so I can see where the terminals should be connected to the switch.
Thanks and Kind Regards
Izak Krige
Izak Krige
