Hi Everyone, my first post here.
I just acquired a Maximat 7 7X17 mini-lathe and mill unit.
The lathe had been used a lot and is in good condition - I cleaned and relubricated and tightened everything according to the service recommendations in the manual.
The lathe seems to all work fine.
But the vertical mill had not been used for some time - all the grease in the gear head was thick and stiff, and the gears were jammed.
Taking the gear box apart, I found all the gear teeth to be intact (yeah ! ), but they had been re-assembled incorrectly.
With the help of the parts manual and a YouTube video, I was able to get the gears back together properly.
Now the right hand shift lever works fine.
All the gears now shift through all the speeds an turn easily. (though I have not run them under power yet)
But the left hand shift lever is missing - well sort of missing - the broken pieces are in a small box that came with the mill.
I have enough of the pieces to make an accurate template to make a new shift lever.
Has anyone done this - and any advice?
The original was a soft cast metal that was not up to the task. (maybe the grease had become too thick ?)
I'm thinking of making the new one out of thick aluminum.
Any suggestions or references ?
Thanks
Jim
Thanks
Jim
