I have read this (see below) but the person did not say what wires to put the cap onto. This seems like a way to keep the soft start but eliminate the zero start. And it sounds like it might work for any treadmill motor controller. I am using this in a drill press. I need to keep the set speed between holes. Thank You.
This is the copy from someones else's post.
"I have developed a simple way to bypass the MC60 motor controller requiring returning to zero speed before starting.
Simply place a 100uF/50v cap between the black and white terminals with the negative leg on the black.
The cap acts as a temporary short, simulating turning the speed to zero. Now you can set the speed, turn it off, turn it back on without changing the speed setting."
