Hi
I´m planning to put an ELS on my Bernardo Profi 700 Pro lathe. This is the same lathe as Warco WM290V, Weiss WBL290 and PM-1130V
I plan to use
Clough42 display and controller and controller board as James described.
NEMA 23 Integrated Easy Servo Motor 180W 3000rpm
5:1 Worm Gearbox NMRVS30 Worm Gear Speed Reducer mounted direct n the lead screw with an adaptor that sits where the banjo was attached. Bothe the servo and the gearbox will be purchased from Stepperonline.
The servo will be driven at 48 VDC
As you see from the model the servo and gearbox fit nicely without modifying the cover.
Anyone that sees a problem with the use of a gearbox?
![1719735093724.png 1719735093724.png](https://www.hobby-machinist.com/data/attachments/452/452504-d43c78c6949119f8f8c194c7a79c7fb3.jpg)
![1719735137238.png 1719735137238.png](https://www.hobby-machinist.com/data/attachments/452/452505-76e6710ad5c9260ae07c6c44782eac86.jpg)
I plan to use
