Gents, I just picked up a used dust collector on craigslist for use in my woodshop, all things seemed fine for it until I got it home and double checked the motor tag, see attached. As you can see, it's mostly in Chinese and lists out, 220v, 18.2 amps, 2840 rpm, and 50hz. That last part is what gave me pause, 50hz. I did some superficial googling about running 50hz on 60hz supply, but I don't feel confident on trying to put this into use. I paid $150 for it with no expectation to spend more than the cost of changing the plug over to match up with my 240v outlet. My question is, can I use this motor as is? If not, what do I need to do to put it into use? Would I be out less money to just find another motor? Thanks in advance for any help you can provide! Merry Christmas!
