- Oct 15, 2020
- 208
Gentlemen,
Have it installed on Milly (727V).
I must begin with two "philosophical position statements", that strike me as the raison d'etre of forums like this one:
1. If you can't open it, you don't own it (gatekeepers can bite it - I bought it, it's mine! I'm not concerned with warrantee, I'm concerned with my concerns!)
2. "Why" isn't really a valid question in the context of a home machine shop....
(got that last one from This Old Tony, and it is self-evidently true. One who asks "why would you, when you could... or should..." doesn't really understand)
Examining the documentation and the gizmo, there is a USB-b connector on the back, and the PDF instructions I've attached discusses serial communication (section 10.3).
1. There is the oEn_nod option that asks for a password - PM tech support seems confused by the existence of that - anyone know the password? (Electronica is thus far unresponsive). I am offended by a tool, that I own, ever saying "no" to me - What do you mean no? I own you! Obey me, tool!
2. The table of contents briefly says RS232 serial, but USB is NOT RS232 - if this thing is RS232, the discussed Hyper Terminal connection would be impossible without a hardware converter - Chart shows 8-n-1 serial protocol, so the USB should be outputting really generic binary, simple to read via serial gizmos, and should be 5v - but RS232 is 12v... I'm looking to output real-time position data via USB, but the options SERIAL and SER_CON shown in the documentation does not appear on my DRO... WTH? Any info on that?
3. What kind of switch is the probe input looking for? NC or NO? I am not about to spend $900 on a switch-on-a-stick from DROPros (sapphire or no sapphire, that's indefensible). It's a 3.5mm mono-phono, easy enough to make - but does it want a normally open or normally closed switch?
Any help would be awesome - remember the days when you could twist some wires on a parallel port, write three lines in BASIC, and make something go?
