- Sep 8, 2012
- 26
I'm not sure if this is the right forum, but it pertains to an Atlas milling machine, so why not?
The spindle on my mill is a MT2, as you all probably know. I'm going to build a vertical head and have decided to just buy a lathe spindle instead of making a spindle. I got a spindle from an Atlas 12" which has a MT2 taper (I was told by the seller). I specifically wanted the same taper in both spindles so that tooling could be interchanged. Problem is, the bore in the mill is smaller than the bore in the lathe, in other words a collet that fits correctly in the mill spindle falls way down inside the lathe spindle. Since they are both MT2, I thought that the bores would be the same.
So educate me about tapers. I thought (probably incorrectly) that all Morris tapers were the same angle, and the number was the size of the bore (i.e. MT2 is a different size than a MT3, with the same angle of taper in both).
Where is my thinking flawed?
