I own a small finger brake and can bend up boxes. Most of the time these boxes get the job done but don't look very classy. I decided to try my hand at making a box from aluminum extrusions. I started with a 1/8" x 1.5" x 0.75" channel section and mill the inside square. Then I closely fit aluminum 1/8" x 0.75" x 0.75" angle on the ends and secure them with a screw from the inside. The angle has a through hole and the channel is tapped. The screw barely extends through the channel. Then I mill the ends so the end of the channel is perfectly flush with the angles. I finish off with my belt sander on the ends and bottom. Now the screws are flush. The top plate is a close fit to the angles and the top of the channel. I have not found a way to attach this top plate that doesn't get in the way of the inside space. Maybe two screws in diagonal corners won't look too bad.
This box nicely holds a 9V battery and a 1" square circuit board.
I spent some time today playing with my new HF powder coating machine. The box and cover plate look good.
Rick Sparber
Rick Sparber
