I got a very early harrison L5 for free, in good shape and I am starting to use it at the moment. I have 2 questions about it.
The first question is one I stumbled upon when trying to find the build year. I was trying to figure this out with the serial number of the machine, but this is where my question starts. It's a weird serial number and I can't find anywhere what it means. It clearly says 'Lasso' and 4469 at the tailstock side of the bed. Also F /I\ H on the other part of the bed at the tailstock side. foto's attached where you can (hopefully) see it. Does someone recognise this? I already found the list of serial numbers on lathes.co.uk , but it's not in that list.
My other question is about the oiling of the headstock of the lathe. I filled the headstock with a generous layer of hydraulic oil that I had laying around. The problem is that when the lathe is turning the oil comes seeping out of the right side of the lid that is put on the headstock. You see in another picture I attached (from lathes.co.uk) that the headstock is 'round' and that the oil follows the inside of the lid, and than seeps through it at arount the sides of the spindle shaft. Could this be because my oil is to thin or do I have a more serious problem?
