Photos on Early Atlas, I'm trying to get the lead screw drive setup working, I have (2) 64 tooth gears and then another gear 20 tooth that fits inside with a metal bushing inside, my question is does the smaller gear or the larger gear engage the spindle gear, both seem to be able to engage the spindle gear depending on which way you install the the 64/20 tooth gear facing towards or away from the headstock on the banjo mount. On the combination gear I'm missing the bolt that mounts it and is there a washer or spacer on it? On the lower gear that fits on the 3/4 shaft that drives the lead screw obviously I need a key for the keyway but are there spacers on both sides of the gear or just one, This would help also in answering the 1st question as to positioning. Thanks for any info. I'm really enjoying reading through all of the threads. The parts books and pictures I have just show a stack of gears not anything that shows how the 64's fit together. Eric
