Hi Guys,
I have an E-35 set of collets for my lathe. I also use them occasionally on my milling machine using
an R-8 collet holder. I was too lazy to change out the collet holder today so I chucked up a 3/4"
end mill to do some milling of mild steel.
The question is this: Does an E-35 collet have enough holding power for heavy machining using large end mills?
If I were to install the end mill in an R-8 end mill holder, it has a set screw that bottoms out in a flat on the
end mill. This seems much more secure to me.
I'm afraid to take more than 10-15 thousands with the collet holder holding the end mill.
Ken
Ken
