The milling-grinding-drilling and slotting attachment is commonly referred to as a Versa- Mil. It is a compact, portable unit capable of doing many machining operations that normally require expensive single-purpose machines. With the different attachments that are available with the unit, drilling, shaping, milling, and grinding can be performed quickly and inexpensively. This self-powered, vertical-feed, variable-speed precision tool may be mounted in any position on the carriage, table, ram, turret, or tool arm of other machine tools. With a two-directional feed table, the Versa-Mil unit becomes a complete machining tool for bench or inplace machining of parts too large to be moved or held in conventional machine tools.
This is my machine l gave $700 for it years ago would like to get what I gave for it used these in the army we had them because of compact size and easy to transport
