- Dec 3, 2017
- 2,131
I've got a dual voltage single phase motor I'm really trying to will back to life here. I thought the motor leads were damaged but they aren't. It all looks fine.
I'm used to three phase motors, but don't know what I'm doing with this. The internet didn't yield anything I didn't know.
The motor doesn't smell burnt, but it's been out of service for many years. Perhaps the smell fades. Meter between L1 and "L2?" reads resistance long enough for the meter to beep, but then the tone stops and the meter reads OL. Meter between windings reads resistance, although I just realized I didn't see what it was. I just listened for continuity and moved on.
If I plug it in through a 15 amp breaker, the breaker trips immediately as soon as I flip the switch. If I go around the breaker, the motor makes a noise...kind of a hum, and the amp clamp got to 13.9 amps before I shut it down.
I think I'm being clear here, but you tell me. FLA is 8.6 for 120 volts, so 13 at start up didn't seem unreasonable to me. But the spindle didn't even jump. I guess a cap would be cheap enough to try before I abandon all hope. Any thoughts?
