Anyone have any experience or tips on sealing the outboard shaft on a Nema 34 stepper motor? As delivered the outboard bearing is visible and open to coolant and swarf contamination. I've measured the motor end cap bore at 28 mm and the shaft is 14 mm. I was thinking of using a lip seal but can't tell if the bore is machined or is "as cast" so I don't know if the bore is concentric to the shaft. I'm building a coolant shield but I'm not comfortable that it will provide enough protection given the anticipated volume of coolant and swarf.
Thanks,
Tom S
Thanks,
Tom S
