- Nov 2, 2012
- 415
I'm curious if I'm doing it wrong. I was drilling aluminum to make a set of highway pegs for my motorcycle, and the bar to clamp to is 25mm. I quickly worked up to 1/2", then grabbed the S&D bits. But even the smaller sizes grabbed the work and spun the chuck off the taper before they ever really got going. Jacobs chuck, JT33 and a decent quality R8 arbor (can't recall the brand but it wasn't a MiC cheapie.) I ended up using the boring head to go from 1/2" to 25mm which worked beautifully, though a lot slower.
So I guess I'm wondering if the S&D drills are too large for that sort of chuck, and if so, what would be more appropriate? I'm also wondering whether I should be concerned about damage to the chuck. Nothing looked out of sorts with a quick look, and smaller drills a couple of steps later acted normal.
Thoughts?
Thoughts?
