DRO on a Zay7045 milling machine
ChrisBoon
H-M Supporter - Silver Member
Jul 16, 2022
36
Hi. Has anyone installed a DRO and a power feed on the Zay7045 milling machine X axis. I do not want to put the DRO scales on the back of the table unless I really have to. I believe the RF45 has the same table. I can mount it on front of the table but then I have to remove the power feed stops. If it has been done, please give me an idea of how to do it. Maybe I can manufacture some kind of bracket?
Thanks in advance for any ideas
Chris
Not sure why you want to mount the scale on the front? I would be much more out of the way in the back.
Anyway, here is a link to how I mounted my DRO, hope it helps.
Thanks Eddy. You sure helped a lot. I was worried that I would lose too much movement on the Y-axis. I have now decided to mount the scale to the back of the table. Your advice is really appreciated.
