- Nov 6, 2012
- 159
I picked up a LMS 2-axis DRO for my 7x16 mini-lathe. The kit uses magnetic scales and TouchDRO hardware & software. The scale/sensor installation instructions are iffy and while LMS has great support, I thought I’d get some input from the knowledgeable folks here.
The cross-slide install instructions are probably not written for my 2013 vintage 7x12 upgraded to a 7x16, as the measurements for mounting the stationary sensor on the saddle slide and scale on the cross slide leave too little distance for the sensor. If I mount the sensor as low as possible on the saddle slide and the scale as high as possible on the cross slide, it might just work.
While the sensor should not touch the scale in operation:
1. What’s the maximum gap for function?
2. What deviation from parallel for the scale is accepatable?
These factors might vary with brand of scales/sensors, but it looks like these come from SEIG, so some may have insight on the brand https://www.siegind.com/magnetic-scale-digital-readout-system
Thanks!
BRET
Thanks!
BRET
