Dro Install Grizzly G1008 Knee Mill
Dman1114
Jun 28, 2014
176
I purchased this older Grizzly mill a few months back....
I decided to go with a 3 Axis Dro with Glass scales. and use a Igage absolute for the Quill....
I went with this for the Main 3 axis
http://www.aliexpress.com/item/High...xis-digital-readout-and-3-pcs/1556577283.html
Ordered it on the 21st.... and it showed up at my door on 27th...
I also bought 2 of the Igageing absolute dros.... 1 for the mill quill and one for my Lathe tailstock....
I decided to start with the Quill and get that out of the way first.....
I feel everything Came out pretty Good.... And i was able to Keep the use of the quill Stops...
Still need to fig out what to do with the wire and the display.....
That's a nice job! Very clean installation and I'm saving those pictures. :)
I know a stop isn't necessary when you have a DRO, put when doing repetitive work it's so nice to just bang into a stop for depth and not have to stare down a number display every time.
For the wire and display, I would wait until you install the 3 axis DRO and see if you want to group them together. Then you have to figure-out where to put the DRO display. It's never ending!
Thank you... little late, well not really but i think i like it right where i put it when i was trying it out .
Just had to make it more secure ...
I took the factory bracket that was made for the scale... made a spacer bushing for the thumb screw and mounted it to the lower side of the cover... tapped it for 2 4mm screws..
now I'm gonna look for a short cord (if i can find one???) and tidy up the wire....
Glad i have a decent assortment of taps.... made this go a lot easier... lots of drilling and tapping.
The only place I know of that sells cables that will work on igaging scales is D cables (http://www.dcables.net/).
They use a mini B to mini B that's male to male, almost impossible to find.
It's hard to find on their site as well. They sell 2 lengths, a 6' and a 3' if I remember correctly.
It took some searching but i found one..... maybe this may help someone else in the future...
Its 9.25" long.... should be about perfect.
I removed the Link to the cable because it is a 4 wire .... and needs to be a 5 wire.
this one did not work
I'll see if I can fins the ones on D cables and add the links. Seems I remember them being a lot cheaper there.
I have the same mill in a different flavor. That thing was a pain to decide where to mount my scales. I did my quail similar.
I know its been some time..... But i got busy with other stuff going on and i really only needed the DRO on the quill...
So this weekend i got some ambition and decided to tackle the Main DRO.....
This dro i got From Aliexpress...http://www.aliexpress.com/item/High...xis-digital-readout-and-3-pcs/1556577283.html.
Im very pleased with the DRO... I Gave them my measurements of my machine and the sent me the scales cut to the size i gave them.
everything went pretty smooth so far. Ive only done the the X and the Y.....
I need to come up with a plan to tackle the Z at a later date. But for now i have the X and Y.
I still need to trim the lower edge of the X cover. then i have to make some new extended gib locks .
otherwise its all set... here is some pictures..
