Hi All,
I tried searching for DRO advice, however the HM search function filters out short words like "DRO" so it has been difficult to find what I am looking for.
Issue: Something is up with my lathe and the carriage hardweel readings can be off by 1/4" or more over lets say 4" of travel. They also don't repeat, so if I back off and return to the same number, the carriage is in a slightly different position. This leads me to use the compound slide for any precision work in the Z axis of the part (limited to 3.25"). I fear something is loose or broken in the apron gearbox, but I haven't had it apart to see.
Specs: I would like to get a DRO that can offer basic features plus maybe a tool offset table. I would like the cross slide to read in 0.0001" in diameter mode (1um scale) and the carriage to read at least in 0.0005" (5um scale). My cross slide travel is 6" and my carriage travel is 31.5".
I talked to DRO PROS and they quoted me $600 for a basic glass scale setup and $1000 for a magnetic scale setup. I was hoping to spend not more than $600. The EASSON EL-8A with the $600 kit seems super basic (but maybe does all I need). They get great reviews so I'm open to spending a bit more for the good stuff.
I also looked on AliExpress and found several kits which meet my specs for under $200. I think I've seen people on here say they have DROs from China that work perfectly and are accurate. I've also seen complaints about accuracy. Does anyone have any definitive advice on if I can trust the accuracy of the Chinese DROs? If they're pretty much the same as the DRO PROs models then I would be very tempted to try it out at $170.
I was looking at this one. They offer slim 1um scales at no added cost over the basic package. LINK
Thanks for any advice and sorry for doubling up on a question I know has been asked here a thousand times.
Mike
Mike
