Drillpress update
chatter chatter cut cut
Jun 21, 2021
139
went out to home depot ,menards, and harbor freight, looked at drill presses, finally bought a wen 10 in at menards. spent the morning assembling it and some time making it run quiet. the thing that helped the most was a 1/2 in thick piece of foam between the motor and the belt tensioner.it really hums low now. decided that fixing a 30 year old $20 at an auction drill press was a real waste of time. and the 1/2 hp motor ran the wrong direction:confused:
the motor will go back into deep storage the burned up 1/4 hp will salvaged for the bearings and motor shaft.the chuck had .004 thou runout tried the old chuck it was only .002 thou. guess the old stuff isn't all bad.
The runout might be the chuck itself, you could pull it and check the spindle. The old chuck might fit if it's better.
