- Jul 15, 2020
- 422
I made an adaptor that allows me to use a Jet 1/2 ton arbor press, a Milwaukee right angle drill attachment, and a cordless drill as a small drill press. The head of the right angle attachment fits snugly into the adaptor and is held perpendicular to the work.. The adaptor has a 3/8" dowel that fits into the hole in the end of the Jet 1/2 ton press.
The result is a setup that weighs under 20 lbs that can be clamped to a flat work surface. The little 1/2 ton press has amazing pressure when applied to a drill bit. I have been using 1/4" hex shank HSS drill bits that fit the right angle attachment.
Im not sure how practical it is, but I was amazed at how well it works.
