- Dec 18, 2019
- 7,428
Learned the hard way previously about over sized holes when drilling with ordinary twist drills and drill presses with poor bearings.
What kind of allowance does one make when using a milling tool to make a hole? For instance, in my shop I have a roughing mill that says it's 1/2". Using a mike, it's 0.497", if I recall correctly. If the hole is pre-drilled at 7/16" or slightly less, and then this roughing mill is used, what hole size could one expect? I know no one knows the exact answer, but what would one typically expect?
