Drilling the end of a threaded rod
oskar
Nov 24, 2013
268
I have a piece of 1” long steel threaded rod 3/4-20 and I like to drill / tap one end for 1/4-20
First question: which chuck is better for the job; I have 3 jaws self adjusting and 4 jaws independent adjustable chuck
Second question: what should I use to protect the threads when I secure it to the chuck or perhaps there is no need for any protection?
Thank you
Depending on the precision you need, the 3 jaw would likely work and is the easiest to use.
I would take a piece of copper pipe, split it length wise and heat it red and let it cool. That will soften the copper.
Wrap your threads with the copper and snug up in the chuck and the threads will be fine.
Without the copper, it is really easy to mar the threads.
I have done something similar with a 3-jaw. In my case, I wound some bailing wire in the threads. The wire was large enough to stick out over the threads. It worked for the accuracy I was looking for. I've used copper wire too.
another method for protecting the threads is to tighten 2 hex nuts on the threaded rod and hold one of the nuts in the 3 jaw
you may lose a little concentricity by this set up, but it works for non precision projects
If the chuck jaws are smooth, little damage will be done by chucking with moderate pressure, to my experience; one might think that a collet would be best, but it is difficult to get enough pressure to avoid slippage with most collet setups.
Tighten 2 hex nuts is a good idea but in my case the thickness of one nut is almost more than the length of my piece so I can’t do this. The next easiest way is to wrap the threads with 12 AWG copper wire.
Many thanks to all
You're well on your way with the above advice, all of which is sound. For the memory bank though, here's a couple of other ways you can keep in mind. One is just to split a nut on one side so it acts like a collet, the other is cut right through a nut and use the two halves like jaws. Both ways work, and I just toss the pieces into a bin for the next time with that particular thread.
-frank
Francist, great idea! I was going to warn to never chuck a thread in your jaws diectly, but to turn a round collet and split it - but your nut idea is far better!
Hi Guys,
If I get that situation, I just use the correct size split die and clamp it in the three jaw chuck.
No thread damage and self centering. You can use the die face and the jaws face for aligning the work.
Otherwise the split copper tube works just as well.
-frank
I've come across this acouple times and always had great results with a slit in the nut. You can do two to get more contact area "support" But u said your part is short. Piece of copper pipe about the same diameter with a slit works good too.
