I have drilled holes for years on a drill press and never thought too much about hole size until recently. I was drilling and tapping holes for 1/8"-27 NPT ports on a project. The fit was a bit loose and decided my cheapo drill bits were the problem. Here's my setup:
PM 935 TV Mill
Glacern R8 drill chuck
Keo 90 degree spot drill
1/8"-27 NPT tap
Tap guide
11/32" jobber drill bit - 2000 RPM
1/4" thick 6061 aluminum
WD40 cutting oil for drilling and tapping
Costco 115 piece drill bit set (10 years old) 118 degree
I decided my cheap drill bits were the problem and picked up a set of Triumph 118 degree bright bits from Enco on sale. Things got much worse. The 1/8"-27 fitting were pretty loose in the newly tapped holes even more so than the tapped holes made with the Costco bits. The Triumph bits chatter and screech a lot even when withdrawing the bit to clear chips. I clear chips maybe every 1/32" of an inch while drilling.
I know drill bits are typically under size. The Costco bits were more undersized than the Triumphs. Does anyone have any ideas for things for me to check on? I was really surprised by all of the noise the Triumphs made even when the holes were spotted prior to drilling with the xy gibs locked during the entire process. The end goal is to get a properly tight thread.
Thanks,
-Joe
PM 935 TV Mill
1/8"-27 NPT tap
Tap guide
Thanks,
-Joe
