- Aug 14, 2011
- 101
I have read several recent posts asking about drilling holes in harden steel calipers. The hardened stainless used in these calipers is indeed tough material but it is no match for carbide drills.
Photo 1 - a hole I drilled in a 4" caliper used on my tailstock.
There are two choices. You can buy a solid carbide Atrax drill for a little over eleven dollars plus shipping. The other choice is go to your local Home Depot and buy a carbide tipped drill sold for masonry use, price a little over four dollars. The masonry drill will not have the sharp edge that the Atrax has but if you have access to a diamond wheel you can improve the edge on the masonry drill very easily. The drill will easily make a hole in your caliper as is but the sharper edge gives a cleaner hole and requires less pressure.
Photo 2 - a masonry drill with an improved edge.
I keep a 1/8” and 3/16” drill close at hand for just these type jobs.
[FONT=&]Jim[/FONT]
[FONT=&]Jim[/FONT]
