- Nov 20, 2022
- 86
So here's the deal, I'm about to do my first machining project on my little Unimat SL.
The job itself is pretty straight forward: turn down a 1 inch rod of acetyl to 25 mm, (removing about .050 if my memory is correct) , make a hole on the centerline of the rod with an ID of 15 mm, and then part them off at 6 mm intervals. Yes, you guessed it, I need to make some new plastic spacers for some chairs that have lost them over the years.
So I've got my acetyl rod, I've got my lathe, I've got my HSS tooling, and now I'm stuck. Here's why.
On a normal lathe, this is an easy deal. Use a spotting drill or a center-drill, then drill it in increasing increments until you get to the final 15 mm ID.
But the Unimat is NOT a normal lathe. The chuck only holds a 1/4 inch shank bit. And a normal 15 mm drill bit is almost as long as my lathe itself.
So I have to go with plan B: boring bar. But that too presents a problem, because the smallest boring bar I can find requires a 5/16" hole, and most drill bits sets are a 3/8 inch shank.
So as I see it: my options are:
a) drill them individually on the drill press after turning and parting them.
b) grinding or turning down a shank on a 5/16" bit to fit and using that for the clearance hole for the boring bar
c) Buying a set of stubby spiral drill bits and still having to turn the shanks down
So Unimat peeps - what do you use to drill a clearance hole for your boring bars?
