Hi I want to make a tap follower for the lathe/drill press/mill. I’ve been watching the series Tubalcain put out on the subject. I want to create the center for the follower. Lyle suggests using drill rod stock, and then hardening and tempering it. I don’t have drill rod and I was wondering if using a grade 8 bolt, or a socket head cap screw would be a similar type of metal that could be anealed, machined, then re-hardened and tempered? Second question, if either of these would work, then would they get water hardened, or oil hardened?
