Drill press upgrades
Mark_f
Jan 16, 2020
5
I hope this is where to put this. I made drill press upgrades I made for about $15 that is money well spent. The first upgrade is a knob upgrade. The wimpy little knobs that came on the drill press were hard on my old arthritic hands. I ordered the nice big red knobs from McMaster Car for about $ 8. The next upgrade was a DRO made out of a 4 inch digital caliper. I do a lot of set depth hole drilling and this is so much more accurate than what came on the drill press. I bought the caliper at Harbor Freight on sale for $6. I found you can’t drill them ( very hard) so I used my Dremel with a cut off wheel and cut off all the points and about a half inch of the rear tang on the sliding piece. I then used a carbide burr in the Dremel and ground two notches for the anchor points. The two nuts on the one screw let me adjust the anchor point for a nice smooth operation. I made the aluminum collar on my lathe. I am going to use this same idea to put a DRO on my lathe tail stock but it will be easily removable. If you have any questions let me know.
Mark
drill press DRO.jpg drill press DRO2.jpg drill press DRO3.jpg Knob upgrade.jpg
Neat work, looks good. How did you secure the ally collar to your quill?
Cheers Phil
