- Aug 27, 2016
- 5
Hello everyone, I'm new to the site; I've been out of machining for awhile, but have recently been tooling up. I just added a 20" Rong Fu VFD drill press to the shop and it arrived a little worse for wear. The depth stop handle was broken off, as was the electrical box holding the VFD. I reamed and tapped the motor casting and reattached the VFD; I got a new kipp handle and repaired the depth stop; I also fitted a used Jacobs 14n into the press on a new arbor. Thought I was ready to go, but here's where it gets squirelly. If the spindle is turning, lowering the quill causes vibration and it seems to meet resistance on the way down and back up. After removing the belts, they check out fine. The pulleys are all running smooth. I marked the spindle pulley and found that the quill only retracts properly on about 1/3 of it's revolution. If the chuck is turned into the other 2/3 of its revolution, there is resistance and the quill stays down due to some internal friction. The return spring is adjusted properly. Does this sound like a bent spindle? I do not have the setup to check runout at this time, but it's minor if there is any. Can anyone help diagnose this? Maybe the low price on this machine wasn't such a good deal after all...
