In a separate thread I mentioned that I own a 13" Taiwan made drill press that has always been faithful to me, but at about 40-45Kg, it's too much hassle to carry around. Therefore, I purchased a smaller one (8") some time ago to take with me when I go to places. It's far from great, but it's only 16 Kg, so it's far more practical when I don't foresee anything complicated.
Still, I've been thinking for a while on ways to improve it and the first thing that came to mind was to add an idler pulley to get a larger range of speeds. To my surprise, after a bit of research on the topic, I've discovered that there are actually small drill presses with idler pulleys already. This one goes by several names (the first I found is sold by Shopmax) but a more generic DP13 "9 speed" shows many distributors in Google:
Don't know where it's made, but I think it comes from India, which explains the "adventurous" nature of the proposition. I call it that way because, if you look carefully at the pictures, you'll notice that the entire head (and many other parts) is made of stamped steel. It weights 12 Kg according to specifications, which is a good 4-5 less than a similar sized one with cast iron parts.
I wonder where I can get a set pulleys readily made...
