HI everyone,
I am a plastic model builder. For a long time I have been considering learning how to machine metal parts to enhance plastic kits. Because scale models are small, most of the drilling is done with .5mm (.1819 inch) bits or smaller. Many of these fine bits get broken while using a pin vise in plastic alone. I use carbide and HSS bits.
My current project requires me to drill small holes into 8mm (3/8 inch) stainless steel tubing with relatively thin walls. I know that I cannot do it without a drill press. But I don't know if it can be made to work with such fragile bits.
I don't even know if a center drill has a fine enough point to start such a small hole. So all of this makes it difficult to invest in tools that may be too big for small tasks.
Thank you for your thoughts.
Gary
Gary
