Drill Notes?
EricB
Feb 15, 2020
418
Am I correct in thinking the finish drill called out here has no point at the end?
Eric
It would need relief angles too so really I would need an end mill?
Eric
You just grind it like a regular drill point, only with no point, we call it a "flat bottom drill". I grind them with a normal primary clearance of perhaps 4 deg. and then a secondary clearance angle, more or less looking like the end on an end mill. also clearing the web, as is done on an end mill that is center cutting, all this is easily done on a regular bench grinder.
