- Feb 7, 2013
- 2,534
My first thought was to order a K-3 Jacobs Chuck Key on E-bay so looked over the goods a bit and found out that the key has 11 teeth. It seemed like
a good morning to try and make one since it is -16F outside and 70F in the shop and no other projects pressing. It was somewhat of a measure on the
chuck and take my best guess at the angle of the gear teeth. I set up my 90-1 rotary table and used the 44 tooth hole count so each tooth would come
out to 8 turns plus 8 holes on the RT. All in all, not too bad for not knowing anything more than the tooth count I guess. As long as I am set up, I might
as well make another one since I was given two of these N-14 chucks with no key from a friend who pulled them out of the scrap bin at work. That was
another project as the chucks were needing disassembly and cleaning which I had done previously. Here's a couple of photos from the morning's POTD.
Just centering the key body in this photo.................
Here I am milling the teeth, used a gear cutter that looked about right for the job..........
I used my digital readout for even tooth depth using the Y axis and just eyeballed
what looked to be a reasonable depth...
Although probably not as precise as the original key, it works fine so was happy with the outcome.
I used a piece of 5/16 inch H-13 steel for the T-bar. Now I have two N-14 Jacobs ball bearing chucks.
One was fitted with an R-8 arbor and the other I set up with MT#3 for lathe use.
