Drill bit lengths
34_40
Just a beginner
Nov 2, 2013
969
What's the difference in drill bit lengths? i.e. - Jobber / Machine etc. etc. etc.
Screw machine drill bits are shorter than jobber bits. Also known as stub drills. They flex less, so they are better at keeping centered.
Cheers Phil
I can't explain all the different lengths because I just don't remember but here are some of the explanations.
Screw machine, short overall and flute length which makes it more rigid. Originally for use in screw machines.
Jobber, general purpose drills for high production
National aircraft standard, similar to jobber but always has a 135 degree point
Taper length, same length as taper shank drills of the same size but with a straight shank
Extra length, self explanatory, they have a extra long fluted section for drilling deep holes. come in lengths up to 14"
I'm sure there are some I've forgotten but its lunch time so time to go.
Thanks for making the time to respond. It is appreciated..:))
I think that there are mechanics length drills too, which are between screw machine and jobbers length
